What do I need to convert turbo oil feed line to flexible line?
84GNTTYPE
Senior Member
Just as the title says. I want to get a steel braided/teflon line made for the turbo oil feed . . . but they don't make them with the stock inverted flare fittings. What do I need/where can I get it to make it fit either a standard pipe fitting or something else that a hydraulic shop can make.
I've done a search and haven't found a good answer.
Thanks for any help!
--John
I made mine myself. Summit seems to have a good selection of fittings at a good price. I forget the sizes but they make a pipe to -AN adaptor which is what you need. You get rid of the brass fitting on top and go directly into the turbo. Did the same on the trans cooler lines. Very easy. Try a search in the general tech. That's what I did when I was trying to find specific sizes. And make sure to use the teflon lined hose.
The brass 90 where it screws into the turbo is 1/8 npt (pipe thread).
