What Ohm Should stock Injectors Be?
TinysTurboPerf
RUTHLESS
Help me find a problem.
Installed two fuel pumps in last week, thinking the first one was the problem.
I pull out of the driveway and the car lays down and spits and sputters(with good fuel pressure)
I do not know if this could be an injector being bad? or ECM with driver problems?
I did read a fault code on Snap-On scanner of 55 which reads Bad ECM, but it did not stay for long as a code? Any hints?
I am going to OHM the injectors today and then thought about changing out the ECM?
Besides the list on gnttype.org, does anyone know of the other cars that these ECM's will work out of? Thanks
