Ok so here we go. After pullin off the intercooler and cleaning it out, lubing the chassis, and changing the oil I bolted everything back together.
Started the car and pluged in the turbo link.
WEll everythign wsa fine until I started seeing error codes detected on the screen. Well the SES light want not coming on and the codes were dissapearing.
So I started to record the data
Here what happen
data screen 1-13
Coolant Temp (138-142)
Battery Volts (13.5-14.1)
Engine speeed (875-1000RPM)
ESC Counts (0-2)
Retard (0)
IAC index (83-85)
TPS Volts (.48 - .52)
LV8 (35-45)
INterger (128-134)
O2 Volts normal Bouncing
BLM (126-134)
MAF (7-8)
MAT (54)
Ok then on the 14 frame this happens
Coolant Temp (-35)
Battery Volts (0)
Engine speeed (200)
Road Speed (80mph!!!!! Im in park)
EGR Duty (12%)
ESC Counts (32)
Retard (40)
IAC index (0)
TPS Volts (.36)
LV8 (59)
INterger (34)
O2 Volts (531)
BLM (83)
MAF (7)
MAT (39)
Then I get codes 24,25,33,34,41,44,45,52
Then NExt screen Everything goes back to normal and all codes Dissapear.
WTF is this, should I be concerned. I know everything is connected properly. Double Checked it
Here what happen
data screen 1-13
ESC Counts (0-2)
Retard (0)
IAC index (83-85)
LV8 (35-45)
INterger (128-134)
BLM (126-134)
MAF (7-8)
MAT (54)
Coolant Temp (-35)
Battery Volts (0)
Engine speeed (200)
EGR Duty (12%)
ESC Counts (32)
Retard (40)
IAC index (0)
TPS Volts (.36)
LV8 (59)
INterger (34)
O2 Volts (531)
BLM (83)
MAF (7)
MAT (39)
