whats do i need
DOUBAD RACIN1
Have a 85 grand nationls motor and trans i put in my 89 s10 pickup...
Went with a tr60 turbo
60 lbs injectors
Every thing else is STOCK...
Want to run a scan tool so i can tune...
Wanted to know what would i need to make this happen...
Thanks..
Assuming right now you're running the 84/85 ecm. You need the 86/87 ecm and a chip for your setup. Contact Eric at turbotweak.com. Then a
scan master or powerlogger will be your choices of scan tools.Avoid boost until you can monitor your truck. Look out for knock retard aka KR or detonation. An audible knock sensor is a good investment with these motors. Good luck with your build.
Yes i still have stock ecu, i also have msd boost controle
As stated by @NorCalTurbos
Boosted cars run on computer code.
The more accurate data you have available for offline analysis, the better decisions you are abe to make.
We tend to push combustion pressures to max mechanical/fuel levels, so the tune is key for performance and longevity. Don't be fooled into thinking otherwise.
