why me
pitoturbo
new turbo ta-49 /50's injctrs joe lubrant chip /timing belt (double roller) front cover highvolume, new springs,w/seals - cam bottom rear main seals / well my car smoke at idle not in the mornings if yo let it sit 15/20 minutes smokes at start up it never smoke before mine question where this smoking coming from / thas why ireplace the seals plus the turbo send some info please !!:(
pete, I still think the turbo is pushing some oil. New or not. Do you have the old on to put on to see if it does it too??
Maybe the seals are defective? Or not put on correct??
i have the new one on/ that's why i replaced it, i thought it was the turbo so i put the ta-49 still smoke then i replace the valve seals, to see if i got the smoke solve, but with the engine cold does not smoke ,once warm if you let it sit it will smoke at start up ::rolleyes: frank give me a call check private mesage
