wideband readings
blackmonte
New HP Technology !!!
What kind of wideband readings are you guys getting idle warm in park ? On a gas car 14.5-14.7 is normal . I am staying at 12.7-13. BL is 130, Iac 21, TPS .42,AF 4, I have a 6.0 TT chip , LS1 MAF , translator set to 1 on base to get the block learn down to 130. Fuel pressure is at 43 hose off,
Mine runs way too rich but in closed loop the Ecm does a pretty good job of keeping the 02's in the 14's. In open loop WB is around 12:1 idle and my blms are 111-115. Haven't figured out why so rich yet. Are you running it in closed loop?
On some of the more recent E85 chips, I've been using open loop idle to smooth it out a little. If it's switching to open loop at idle, the A/F will end up somewhere around 12.5-13.5 usually. It's the same for gas or E85 if your wideband is set up for gas.
