Window Problem
Boosted 86 T
Ever since i bought my 86 TR my driver side window has never rolled all the way up, it used to go up and stop about a half inch to the top and now it stops about an inch to the top...What do you guys think about this?
Pull the door panel and adjust the stops on the upper edges. Check the regulator for missing teeth and lube it all with some white lithium grease while you're in there.
Power windows, right? I only ask that because you said "roll up".
There are some stops in there that limit the upwards travel of the window.
They don't push it up to make it go higher, but they control how high it can go - until you run out of window. :)
You can get to those adjustments by removing the top door panel. They'll be on the far right and left corners.
Then when you figure out how to do it, you can come here and make mine fit correctly.
