XFI 2.05 very long initial crank , any ideas ?
Discussion in 'Performance ECM Upgrades' started by gczarny, Mar 8, 2017.
  1. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    I am heaving really long initial cranking problem 10-15 seconds before it fires up most of the time ,at times it will fire up right away but most of the time it takes that long to get it started ,after that will start right up till it sits for a while and then same long crank problem . My starter cranks fast enough ,new Optimo battery under the hood , cam/crank lights on XFI and XIM blinking but no go for 10 plus seconds .Volts shown by XFI about 0.2V less then what voltmeter reads at the batery ,fuel pressure 45 key on while cranking 50 psi ,battery 10.5 volts or more while cranking , I tried adjusting injector offset - batt volts , crank fuel , timing from 20 to 35 deg , seams no different . Ran out of ideas , anybody have this problem ? I will be happy to post tune and log files in anybody willing to look at them .
  2. Boost231
    Boost231
    Expand Collapse
    What's An Intercooler
    Staff Member
    May 26, 2001
    13,579
    402
    Offline
    Sounds like it needs more cold cranking fuel
    • Agree Agree x 1
  3. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    I did test when I turn key on ,wait 1 min for wide band to heat up and read properly and then crank and watch cranking AFR , tried from 7 to 12 by adjusting cranking fuel ,same thing and it does not matter if this is cold start or engine is at 170 F ,if it sits for 5 minutes it will have long crank first time and will start right up after that , anybody can post their cranking AFR with easy starting engine ?
    Greg
  4. turbo nasty
    turbo nasty
    Expand Collapse
    Goat Milk Racing
    Jul 19, 2001
    7,747
    261
    Online
    Did you verify toming with a light?
  5. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    yes , dead on
    Yes , dead on . Talked to Cal the other day ,he made a point that if the engine stops in "bad spot " it make take a while for XFI to resynch cam/ crank pulses if batt volts are low /crank slow , that's not it ,it cranks fast enough to resynch it in less then 10 seconds , not to mention if it starts I can kill it righht away and after XFI resets it will fire right up every time , the problem started shortly after update to 2.05 from 1.34 but not right away so can not blame it on the upgrade yet .I am out of ideas on this one but I am NOT going to call it NORMAL .
    Greg
    #5 gczarny, Mar 9, 2017
  6. turbo96max
    turbo96max
    Expand Collapse
    Jun 6, 2007
    764
    13
    Offline
    im on e85,initial cold start is slow, then fires up right away as well ,. subscribed...
  7. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,752
    169
    Offline
    I know I have to wait 5 sec or so after I turn the key on to start the car. If I don't wait and hit the key to start it won't start just turns over. Wait a few seconds and it fires right up.
  8. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    That's how I start mine too, fuel prime is set tp 5 sec so I wait till FP shuts off then crank , I will be trying few things over the weekend ,I also smell some gas while driving and I can NOT figure out where it is comming from under the hood , one time I was seeing wet around FP regulator where two halfs are bolted together it was fixed and fine for a while now I smell it again but can not see anything wet ? more then one gremlin here ? or just one ?
  9. turbo nasty
    turbo nasty
    Expand Collapse
    Goat Milk Racing
    Jul 19, 2001
    7,747
    261
    Online
    Check your firmware ver as well
  10. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    XFI 2.051 build date 05/19/14
    XFI Firmware XFI2_B9
    XIM Firmware XIM_20E
  11. Lance
    Lance
    Expand Collapse
    May 25, 2001
    202
    14
    Offline
    While cranking, the stock C3I ignition is in bypass mode and ECU is not controlling spark. The timing will be 10 degrees and trigger directly from crank sensor. There can be a delay as the C3I module will wait for a cam pulse to synchronize and it can take as long as two engine revolutions for the cam pulse to occur. Long cranking is most likely caused by improper fueling or air bypass. Also, if the fuel system does not hold pressure when off, it can take a bit to pressurize. Latest XFI has ability to "pump" extra fuel by pumping throttle before or while cranking (while fuel pump on). If you find a couple of light pumps on throttle before cranking helps, increase cranking fuel. If cracking and holding the throttle open a tad helps start faster, you may need more air bypass (starting IAC pos. vs. coolant temp.) during cranking.
    #11 Lance, Mar 10, 2017
  12. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    That's only true for stock ignition module ,with XIM you have full control of start up timing , I tried IAC start position from 255 to 125 ,made no diference , I have my second FP set up to come on by TPS at 60% ,I tried to pressurise system with second fuel pump few times and this also made no diference , today I pluged in brand new 3bar MAP sensor( car set overnight ) she fired up on first turn ,tried 3 more times waiting each time 20 minutes or so and she fired right up ,thought I had it ........NOT SO FAST , fourth 20 or so minutes wait and back to 15 seconds of cranking .
  13. Lance
    Lance
    Expand Collapse
    May 25, 2001
    202
    14
    Offline
    Yes.. Sorry, didn't see the XIM reference. Are you seeing the cam LED on the XFI and on the XIM right away during cranking? The same applies to XIM; It has to wait for cam pulse to synchronize before sorting spark.
  14. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    yes ,both XFI and XIM crank and cam led are blinking right away but no go for 10 sec .I had spark tester on ign wire and it had spark ,just do not know if in synch .
    Greg
  15. gczarny
    gczarny
    Expand Collapse
    fast is cool !
    Nov 13, 2005
    426
    5
    Offline
    I just wanted to let everybody know that my long cranking problem is fixed for sure , what it turned out to be was wiring/connection problem somewhere , I decided to go through all grounds and connectors I could think of ,unplug - spray contact cleaner - plug back in couple of times -you know the drill , for last 3 days car starts perfect , better then stock car :whistle: ,thanks everybody for input /help with this problem .
    Greg
    • Like Like x 2
Share This Page
