Yo Razor!..the kit is Awesome! LT1 F-body at 21 psi!
MattSwindle
Up to 21 psi and 19 degs so far!
Pulling the heads this week, to get the port job, it so badly needs!
can't wait for spring, to finalize the tune on this 11 to 1 motor
and see what it'll do at the track! (NMCA Bradenton in April!)
Can you give me a target for what you've seen..AFR and Timing vs Boost?
I know I'm in the ballpark.
Thanks Ahead!
Later all!
Happy New Year!
Matt
Go rich.. as rich as it will still make power. Some cars are tuned at 10.0 others at 11.0. Somewhere in between those should get you in the ballpark. Watch you MPH/HP.. tune for max mph/hp.. you'll be fine. Boost will drop when you port the heads.. thats a good thing.
Cheers and congrats.. must pull like a freight train.
Julio
There's no way that car can be fast. It's got a 4L80E transmission in it...way too heavy for any performance application. Maybe you could put a hitch on the back of it and use it as a tow vehicle. :)
Kevin
Matt,
Glad the new pulley helped your boost situation.
You can slowly increase the timing & pick up a lot of power. I'm guessing you are currently leaving close to 100 hp on the table with 19 deg. Most LT1's will make peak power around 26 deg timing at 10-11:1 A/F range.
As far as the 4L80E..... There is nothing wrong with a 9 second tow vehicle, or a race car that you can enjoy driving 60mi to the racetrack with a 5000 stall converter. Lock-up & overdrive... who said a dog was mans best friend?
Local here with a twin turbo'd LS1 ran more boost and less timing and the power was sky rocketing. Car made more power with more psi/less timing then in reverse.
Ported head, 11:1 comp with 21psi sounds like a massive pavement pounder.:eek:
This ride screams for a standalone with wideband locked a/f ratio.
Mike,
Matt has a FAST system on the car with a WB O2. I was just giving him a hard time about the transmission, because that's just what friends do. :)
Kevin
Hey Kev..
thanks for the harassment!..lol
no more nibbles on sellin' the tranny..may stick with it
a little longer...see what I get back on my taxes before I can
decide on the Glide/Gear Vender..I'll know in February..
this car is dyin' for a 'trans-brake' though..
Yo Lonnie..
I couldn't believe the difference from 15 to 21 psi..
gotta figure out what to do with that credit..
more oil..spare belt...another pulley for more boost?!..LOL
Hey Mike..
definitely kick-ass..it feels like it pulls harder than the 450 shot of spray..
I think the footbrake 60' will get back into the 1.4's at least..
Matt.
Let me know what you want for your credit. I'll work with you.
The LT1 is generally good for 20 plus hp per lb. of boost, so I bet you really noticed a difference.
How high are you revving it now? The pulley is about as small as you can go, so short of a custom one, it will only make more boost if you rev it higher.
If you sell the trans, I could use a spare t-comm.
Nice to hear..My father got me Razors kit for christmas and I cant wait to install it.....Could teh pump be any bigger :cool:
Matt.
How high are you reving it now? The pulley is about as small as you can go, so short of a custom one, it will only make more boost if you rev it higher.
I'll holler at ya when I decide what I need most..and if the T-Comm
doesn't go with the tranny..
Still shifting at 6200..don't wanna go too high with the tranny...
it'll last longer...
it wants to pull to at least 6800..but I can wait till I put a Glide in it
with a brake..
it's gonna be really wicked when I can leave at 3 to 4k...!
with a brake..
ENOUGH ALREADY! I WANT PICS!!!!!!!!!!!!!!!!!!!!!!!!!! :biggrin:
Seriously, If you have pics of your setup, either post them up, or even email me a few. Sounds pretty sick!
