Rafs-T-Type
Not so Senior Member
- Mar 8, 2009
Up for sale is my 86 T-type for $17,900
Suspension:
Poly body mounts, motor mounts, and trans mounts
Front is Ridetech Tru-turn system with single adjustable coil overs
Rear is H&R adjustable control arms, with single adjustable QA1 Shocks
Hellwig roll bar front and back
Behind seat braces, underhood braces, jounce bar..the one the connects the trans crossover to the frame rails.
Front end rebuild – tie-rods, idler arms, steering link etc
Jeep steering shaft
Engine:
Balanced and built.
Steel crank and caps
.020 JE forged pistons
Roller cam with unknown grind…believed to be a 206/206
Ported steel Champions with custom guts
120 lb inj w/ racetronix harness – E85 car
6265 DBB Precision w/ .63 coated exhaust housing….coated .82 housing to be included too
Electronics include Scanmaster, Extender Pro chip, Modified ECM, Powerlogger, and Translator Pro
4” CAI
MagnaFuel ProTuner 750 Series In-Line Fuel Pump
Transmission:
Jimmy’s Built for tens
Dusty spec’d 9.5” PTC w/I believe a 3200 stall
Trans brake – which isn’t really needed because the hydratech brakes hold all you need…15psi+
And there's probably a list a mile long of stuff I'm forgetting to mention.
She's not show car and has a handful of blemishes. If you're looking for something perfect keep looking. If you're looking for a bad ass ride that someone else already dumped a bunch of money into, then come take a look. I would give inside and out about a 7.5/10
For some reason this site won't let me post a link to the pics at Imgur, so shoot me a PM for a link to more pics
Suspension:
Jeep steering shaft
Engine:
Balanced and built.
4” CAI
Transmission:
