1968 Chevelle With '87 GN engine
1968 Chevelle
White with black stripes over hood and trunk
Front disc brakes
Power steering
Power brakes
New
1-ball joints
2-springs (moog)
3-KYB shocks
4-brakes
5-window felts
6-wind shield
7-dash Pad
8-recovered seats OE style
9-A-arm bushings
10-quater panels
11-package tray
Engine
1987 GN with new timing chain set, oil pump
To do the wiring i used a caspers "dash mating wire harness"
Brake booster vacuum block.
Cotton’s AC delete pulley
1987 GN gas tank and fuel pump
The car is not finished yet and these are some things that it might get. and yes these things may affect the price
1-'87 OE IC used as a front mount.
2-rebuilt or good used turbo.
The turbo it has now leaks and has play. (in/out-up/down)
3-it has an open 10 bolt rear.
I am thinking of putting in a mini spool. not shore yet
If I have the time I will install new body bushings
And clean and paint the frame
Pictures will be available as the work gets done on the car I do have some before pictures.
The car is not finished.
last night
up date 4-23-07
1968 Chevelle
White
Front disc brakes
Power steering
Power brakes
New
1-ball joints
2-springs (moog)
3-shocks
4-brakes
5-window felts
6-wind shield
7-dash Pad
9-A-arm bushings
10-quater panels
11-package tray
Engine
1-Brake booster vacuum block.
2-AC delete pulley
3-GN gas tank and hot wire fuel pump
4-rebuilt stock turbo
1-it has an open 10 bolt rear.
I am thinking of putting in a mini spool. not sure yet
Well I asked my Dad to please do work on the car.
Then this is what I find when I go to my Dads house.
With a list of parts needed.
Opinions needed
The car is going to be painted white
1-should I paint the fire wall white
2-should I paint the fender wells/ wheel wells in white
3-or should I paint the above in the factory flat black.
I'd stay with the factory colors for the firewall and wheelwells.. I think it had a bit of a satin,. but find out what it is and paint it that. White will be too much under the hood..
The fire wall will be painted white
But the fender wells will be painted black.
These are some pictures of the frame all cleaned up and painted with POR-15
The under body will also be cleaned and painted with POR-15 then
Top-coated white.
My Dad wants to paint the rear-end and drive shaft silver so it’s going to be painted silver.
Pictures on that as it gets done
