1985 smoke stack!!
1QUICK85
Big Old Turbo Turd!!
Here is a link to my post in the hot air section.......just wanted to get some more response on this. I believe I have a blown headgasket.......can I do a compression test while the engine is cold?? What would happen to the readings?? I also checked today and when I rev the engine a couple seconds later a few bubbles come out at the top of the radiator. I am assuming 100% it is a head gasket and dont really want to bother with doing a compression test..........just figure I would jump into her and change them both out. Hopefully it isnt a cracked head!! The exhaust stinks like all he!! but I cant tell if it is anti freeze. Definatly not an oil smell at all.
http://turbobuick.com/forums/showthread.php?s=&threadid=121125
Does anyone have a link to some good technics on removing the heads and installing them..........torque numbers, torque pattern, gasket install with gaskets and sealant or just gaskets??
Thanks much, Nick.
