1987 Limited
dmorgan
Rare optioned with only 1035 made, 2nd owner for over 28yrs unopened motor with 117k. No rust and only one repaint and just wet sanded and polished. TA49, 009 injectors, Dutt neck, SMC (denatured alcohol.), ATR regulator, Kenne bell boost controller, valve springs, new rear seal and pan gasket - no leaks. Terry Houston 3" DP to 3 cutout (never opened) to stock walker exhaust. NEW, NOS accumulator and brake switch, line lock, new brass portioning valve, S10 wheel cylinders and flushed. NOS GM front fillers are in paint now. Trans was freshened up with a hardened input shaft, forward drum work to accept extra steel and clutch with a D5 converter. Car shifts beautifully- the car doesn't miss a beat. Further information (history) and pictures for those interested - 35K OBO car is now in NY from Ohio, family member. DM with contact info and I can text any photo you like. Thanks
Thank you for so many thumbs up. I know this car is very well known considering my family has been a member/moderator for so many years. Unfortunately it has become time to sell - someone will be so happy. I ask only for real inquiries, I thought best and respectful to show it here first. I wish I could keep it !
for sure and legit - Thank you. This car is so special - I wish I could keep her. So much fun and shows well. I thought appropriate to show her here first, this would make so many happy..
I am attaching requested photos and info. Red Armstrong hot wire kit, Reds pump and RJC Power plate. Adding chassis, engine and interior photos from today. Front fillers will be installed before it's sold. I also have walk around video and car running. I will put a more and as requested.
additional pictures
Does it have an upgraded downpipe? How is bost controlled? How recent was the car painted? was glass removed fpor paint work? any pics of prep for paint of vehicle?
It has a 3" Terry Houston Downpipe and Kenne-bell boost controller. Car was painted over 20yrs ago and all glass was removed. I brought it to a professional shop and had it wet sanded flat and polished. The front fillers will be painted and installed this weekend.
Beautiful car. Wish you were closer.
Any trades?
Requested photos of NOS GM front fillers painted/installed and photo of trunk. I'm pretty sure I have answered all the DM's but if I missed you please just call or text
Thanks Dan 516 375-7084
What cindition are the rear fillets?
Did you save any extra paint from the front mix for future touchups?
I will have the rear fillers today and right to paint and install. I intend to post the pictures when completed and then I will put it on ebay or BAT.
Thank you, the A/C has been converted to R134a and everything works. The rear fillers will be painted today and soon there after will be installed. The car needs nothing and ready - just filled it up with 93 octane the other day.
