1st gen F body
Scott Atk
Senior Member
May 25, 2001
2,238
59
48
52
Las Vegas, NV
From the searching that I've done, it seems there's interference between the steering box and the d/s header. What's the best solution? The Uni-Steer rack and pinion seems pretty low profile, does that alleviate the interference?
I'm also interested in anything else that I might encounter. Thanks in advance, Scott
  • Like
Reactions: jess70502
Scott Atk
Senior Member
May 25, 2001
2,238
59
48
52
Las Vegas, NV
Already has Varishock coilovers in the back... Unfortunately, it also has an Alston ladder bar setup, at least it's poly bushed. I'll have to get it on the road before I decide if it stays or goes.
BlackLC2burd
66
0
6
Bay Area, CA
I have about 1/2 to 3/4 of an inch clearance on my first gen with the factory PS box, but it does sit a little higher on the drivers side. It isn't noticeable by other people but I can tell.
Scott Atk
Senior Member
May 25, 2001
2,238
59
48
52
Las Vegas, NV
Talked to American Powertrain today. Wow!! sticker shock for sure. BOP bellhousing, Billet flywheel, twin disk clutch, T56 Magnum, shifter, crossmember, hydraulic clutch kit, driveshaft, wiring, pretty much everything for $6100.
I'm going to call Keisler Monday morning, and see how they compare.
Scott Atk
Senior Member
May 25, 2001
2,238
59
48
52
Las Vegas, NV
Thanks Rick. I'm excited about the project. As far as I know, I will have the only T56 behind a Buick V6 around. UPDATE: I will be going with Keisler for the transmission.
Scott Atk
Senior Member
May 25, 2001
2,238
59
48
52
Las Vegas, NV
Eventually. Just looking to get it running first. I am planning on running E85 + ALKY so it should be interesting to log inlet temps.
Scott Atk
Senior Member
May 25, 2001
2,238
59
48
52
Las Vegas, NV
It's a bit of a leap of faith, but I figured the rack and pinion should allow more room than the steering box. It's a Unisteer unit. I will wait on running the PS lines and column linkage until after the motor is in.
