2 DIN stereo
KCODE
Can a 2 DIN stereo be installed in a 86 Buick GN will minimal mods?
Depends on what you think 'minimal' is.... do a search on Double DIN install there are a few threads... and you will have to cut your dash and bezel (or make a bezel)
Sent from my iPhone using Tapatalk Pro
I did it successfully......go to the audio forum and see my posts. Pics too.
I put in a Clarion NX405 with the 6.5 inch screen with navigation.....
Checking it out looks good.
Kirban sells a kit specifically for a double din to fit the stock space
The above link is for a single din radio.
The only thing that needs to be done (2 things) is that the bottom steel rail need to be shaved down ever so slightly.
THEN, the bezzle bottom piece needs to be removed. A total of about 5 minutes..... Once reinstalled,
the bezzle looks clean.......... (again,see my pics)
In your pics its seems to stick out further than stock. Is that so? Can you get an angle pic?
