2001 Buick Regal GS
87geeinn
Buick and AMG pilot
$12000 FIRM
I modified this GS to be a nice little sleeper while also retaining the original Buick ride quality. Modifications include: intercooler, smaller s/c pulley, ZZP “Powerlogs” and “Equalizer” kit with catted downpipe, fuel pump hotwire, billet fuel rails, cold air intake, PCM tune, 180* thermostat, 600w Alpine mono amp with 10” Kicker Solobaric w/Kenwood head unit. Current maintenance includes: oil change, spark plugs, wires, coils, lower intake manifold gaskets, aluminum coolant elbows, new radiator, ALL new A/C, tensioner and idler pulleys, transmission filter and Dex VI conversion, supercharger oil, valve cover gaskets, engine mounts, struts on all four corners, new all season tires, brakes bled, fuel filter, key fobs, window tint, vinyl wrapped interior trim items, windshield washer reservoir and pump, coolant reservoir, cleaned/resealed PCV, aluminum vacuum fitting, LED headlamps (properly aimed). All work done by yours truly.
Car needs absolutely nothing, zero leaks, and everything works with the exception of the sunshade visor vanity lights. A good companion car for your turbo Regal. Some minor cosmetic blemishes inside and out commensurate with a 23 year old car but presents very well and gets lots of comments. It's a blast to drive and only selling because I have four cars and need to downsize and prepare for an upcoming move.
Car is located in Fayetteville, NC but has a clean FL title.
More pics...
Reduced to $11,500 FIRM.
Car now has approx 106k on the clock as it gets driven every other day or so.
