210/205 or stock replacement
BADASS86GN
I had a 210/205 in my 86 GN and wiped a lobe and dished a lifter. People say my car will run faster if i put the stock one back in. Heads are not ported, TE44, PTE front mount, and 50's. Which would be faster? I ran 7.32 on 21#'s. Can i hit a 6 with my combo and say 26 to 27 psi.
Craig
That cam sounds like a good match for your combo. Based on your 60ft times, you don't seem to be losing anything with the 210/205. Most folks who worry about a larger than stock cam say it will hurt you on the bottom end, but you will pick it up at the high end. I'd say your getting .2 -.3 quicker in the 1/4 on that cam.
I'm getting ready to drop a 212/206 cam and lifters in mine along with ported heads, ported intake, power plate, 60# injectors and a few other needed items.
