What minimum spring pressure is needed to run this cam?. What type of vacum will this cam pull?
It 's the Xtreme Energy XFI Lobe 3015 series. LSA 112
Lobe lift .358 with 1.55 rockers =554.9 lift in my application
I have PAc1201x now with 150LB seat pressure at 1.750 install. Will these support this cam up to 6000 RPM without issues @ .554 lift?
not planning to spin this past 6000-6200 ....95% street car but want the best performance possible
My Combo:
250 CU Stroker Stage1
E85 Fuel-120lb injectors
9:1 Compression-
GN1 Aluminum Heads Race Ported 1.55 T&D Shaft Rollers
Pac1201x SPrings 150Lb seat
Johnson Reduced Travel Lifters
Champion Race Intake
PTE 6466 Dbbl with .63AR
PTC 9.5 NL 17 blade Converter approx 3200 stall
My Combo:
9:1 Compression-
