274" 016 short block
forcefed3.8's
Buckeye Bullet
For sale:
274" 016 4.1 stage 2 short block
4.01 bore custom diamond pistons. Ceramic coated tops, moly coated skirts, thick wall tool steel wrist pins, .010 below deck, 24cc dish, 9.5:1 to 10:1 with a gn1 head depending on cc and head gasket.
6.35" Molnar rods
3.625" Rpm 4340 forged crankshaft
224/224 @112 lsa 3015 XFI lobe cam with high rev Comp 885 lifters, heavy duty Rollmaster IWIS timing chain.
Deep sump oil pan with custom internal pickup
High volume front cover, has 80psi oil pressure start up cold, 20+psi hot idle with 10w30 oil
BHJ ballancer
JW flexplate
HR Parts mounts
Aluminum pulleys
Summit mini starter
ARP head studs, washers, nuts for GN1 heads
Rebuilt cam sensor with RJC washer tab and bolt
The deck is o-ringed
This bottom end has 400 miles on it. Off center like a 109. Intake, headers, accessories, etc bolt up. This is a street/strip engine that will handle 1000hp for years.
$14,000obo picked up in 44039 North Ridgeville OH
