- Nov 30, 2009
SignUp Now!The 295/65/15's are 30.3" tall , that's what made it difficult to fit .I have the 295/55-15’s on mine.
Damn if I would spend the time to drop it down one bit. Your car looks killer just the way it sits. Great job!!!!I just mounted up some 295/65/15 MT DR's , and with a frame notch , rolled lip , and careful measuring for back spacing , they fit like a glove with no room to spare !! I'm going to pull the springs out to see how much farther I can drop the body down , but it's not bad right where it's at now .
View attachment 318003 View attachment 318004
Thanks . When it's up on the lift the springs can be pulled right out because the suspension hangs so low . I would just need a shorter spring or maybe a adjustable spring perch & coil over spring . I really should put in limiter straps so it doesn't hang so low .Damn if I would spend the time to drop it down one bit. Your car looks killer just the way it sits. Great job!!!!
That's looking goodI just mounted up some 295/65/15 MT DR's , and with a frame notch , rolled lip , and careful measuring for back spacing , they fit like a glove with no room to spare !! I'm going to pull the springs out to see how much farther I can drop the body down , but it's not bad right where it's at now .
No I was running the 295/65 years ago.sam has the newest ss version.but he size has been out for a long timeIs the 65 ratio fairly new? I don’t recall seeing this one before
The 65 is just a taller version of the 55 series mt.11.9 belly to belly,10.9 on the contact patch,95 on the rollout,30.3 tallSame here. Only get a tiny bit of rub on the right side on a very BIG speed bump.
Your going to love that tire.more rollout,with more sidewall to take the hit.just hit it with power and you will fly.Not sure if new , this is more of an experiment for the track . I got a great price on them barely used . worst case I sell them barely used .
Yes , it is possible.I think the limiter strap might be a good idea. Is there any way the springs could come out of the pocket unknowingly when you let it down off the lift?
15x10 , I have to check back space , can't remember if it was 4" or 4 1/2" , but my rear end is narrowed 1 1/2" each side. I'll check the specs. on the order sheet from Quick Performance on overall width when I get home .Sam, what are the wheel specs? Am considering them for the LST car...
