3.5" MAF and Compressor Inlet/Outlet Sizes
Blown&Injected
About the pipe that will accept the 3.5" MAF; does the pipe gradually shrink down to a smaller size to fit the stock turbo?
I have what I'm sure is considered a stock replacement chrome MAF pipe. My Turbonetics 60-1 does not have the bell like the stock turbo. The MAF end goes directly to the stock MAF and the turbo end goes to the turbo except that I need to have a piece of hose over the inlet, then the hose on the MAF pipe goes over the inlet/small piece of hose spacer.
It is not the smoothest way to do it all IMO. Does the new set up for the 3.5" MAF clean it up a bit? The stock MAF is 3 1/8" to the turbo that is 2 7/8" (the reason for the piece of hose spacer); then the outlet on the turbo is about 2" and my FMIC pipe is 2 1/2". Is there a turbo with a compressor housing that will take a clean, straight thru 3.5", from MAF to inlet, and outlet with a 2.5" that will not require the adapter hose I now use? - Maybe something that will go into the 10's, or max out my MSD 50's - which I believe would be high 10's.
Thanks,
I don't think so. I wouldn't want it to, anyway.
If there is, it's probably on a 8 or 9-second car. ;) Those are massive portal sizes.
I've done a ton of custom cold-air kits. Depending on the size of the inlet bell/turbo inlet, I machine a piece of aluminum 1 1/2" - 2" long to fit on the inlet bell, and taper out to the MAF pipe/hose size. I don't like the idea of just flanging the turbo inlet to 3 1/2" or 4" [whatever the MAF hose size is], and sticking the hose/pipe on there. It's ugly, and doesn't provide a smooth tract for the incoming air to the turbine housing.
Why would it be bad to have the MAF pipe taper down to the inlet? Seems like it would be the smoothest way - to have it taper across the entire length of the pipe?
Anyway, it looks like it goes from 3" to 4" inlets from what I could find. PTE has a nice site with lots of choices and a bit of good info about every one of the offerings.
This looks like a nice one - any ideas or thoughts on this unit?
Vendor : Precision
Product Type : Buick Performance 3-Bolt
Product Name : TE63-1
Comes with Garrett Compressor Cover - 3" Inlet and 2.5" Outlet, 63mm 56 trim comp wheel, P trim turbine wheel, .63 or .85 A/R.
For mid 10 second applications, 3400 minimum stall required.
These turbo's require a specific wastegate actuator for true bolt-on compatability, sold seperately.
Supports up to 715 hp at the flywheel
Not sure what the "specific wastegate part means? Looks like it says that for all the choices.
This turbo actually has a 4" inlet, not 3". It does have the 2 1/2" outlet though. I just put this turbo on my car. A hole drilled in the middle of the wastegate bracket will enable you to put the stock wastegate on this turbo. It is how mine was put on.
