I've been looking into doing either this swap or the Ford 2.3 turbo. Kinda leaning towards the Buick motor just because it has more potential.
Anyways, for those of you who have done it, what do you use for motor mounts? All custom or does someone make an adapter for it now?
Basically if I do this it would be stock rods and crank with aftermarket pistons, ported heads, ported intake, injectors and a chip, larger turbo, and probably an LS1 MAF. With the pump gas TurboTweak chip and alky injection, what kinda power would the setup make? I was looking into the setup Grumpy posted and that's pretty much what I would do...But in a lighter chassis.
Thanks.
Thanks.
