3 or 4 bolt turbo mount
supercoupe5
274
1
0
Flint, MI
i see on here and on some websites that there are 3 and 4 bolt flanges for the turbos on these cars. is there an advantage to switching to a 4 bolt over the 3 bolt that comes stock on gn's. guess what i am looking for is the good the bad and the ugly.
  • Like
Reactions: 87turbot-type
RUQWKNF
KEEPER OF SECRETS
Staff member
May 26, 2001
2,426
292
83
47
NEED TO KNOW BASIS
s78.photobucket.com
3 bolt vs 4 bolt. A long debated topic.
In a nut shell, here's the good and bad.
3-bolt style
Garrett 3-bolt turbine housing on a TA-49 turbo.
PTE 3-bolt turbine housing.
Factory located 3-bolt turbo with a 3" Terry Houston downpipe attached.
Factory style 3-bolt turbo with external wastegate mounted off the downpipe.
3-bolt good,
Direct bolt on replacement for all 86-87 Turbo Buicks and TTAs. Largest bolt on 3-bolt turbo available without having to change around a lot of stuff is a PT76 GT-Q. Uses the factory style downpipe flange for stock downpipe, Terry Houston style, or external wastegate mounted onto the downpipe style. Factory heat shield will fit over even the PT76 GT-Q.
3 -bolt bad,
Limited flow capabilities once you start looking to make over 975 fwhp. GT-Q is currently the largest turbine wheel option available. Back pressure can become an issue when trying to hit the elusive 975 fwhp mark. Wastegate hole will need to be ported if wanting to run high hp and high boost levels with a standard Internal wastegate style downpipe, in order to maintain boost control. To anyone that knows how to recognize turbos, the larger 70 series turbos would frighten most.
4-bolt style
PT88 Stage II setup with external wastegate and V-band style downpipe.
GT42 series turbo on Stage II with external wastegate and v-band style downpipe.
4-bolt good,
Tremendous flow capability when using the T4 Tangential style turbine housing. Significantly out flows the 3-bolt T3 style housing on 800+ hp applications. Less back pressure at high boost than the 3-bolt. Turbo selection and hp capabilities far exceed the currently available 3-bolt turbos. You can get a GT4788 with a T4 style turbine housing that will support close to 1300 fwhp.
4-bolt bad,
Requires the use of an external wastegate that will need to be mounted either onto the crossover pipe, or off the up-pipe from the header. Requires specific headers or at least a 3 to 4 bolt adapter flange. Will not work with internally wastegated downpipes. Requires a different style v-band clamped downpipe. If you go larger than a PT76 GT-S, you will need custom air intake piping as most turbos larger than the PT76 have 5" inlets. Higher than 4000 stall converters are required to properly spool up non ball bearing turbos larger than a GT4276, even no Stage II applications. Factory heat shield will not work and on larger Medium framed turbos, and will typically scare the poop out of most on lookers.
Hope this helps a little.
Patrick
  • Like
Reactions: GNBRETT
86brick
It's just a V6 Brick.....
Sep 20, 2001
10,467
52
48
118
Florida
home.bellsouth.net
Good work Patrick!
Awesome little write-up on the differences between the 3 and 4-bolt turbos... Great use of pics as well!:cool: This might make for a good sticky!:D
RobV6
634
0
0
NY.
Visit site
Jeez I learned more on this reply. Than any I could remeber.Oh there was one.Thanks for input photos made it really work. JMO
RUQWKNF
KEEPER OF SECRETS
Staff member
May 26, 2001
2,426
292
83
47
NEED TO KNOW BASIS
s78.photobucket.com
Technically, they should both seal just fine when used with a copper gasket and some copper high temp rtv. The T4 would have more clamping force due to the 4 bolts vs 3.
Just my O2s worth.
Patrick
gstenz
1
0
0
What turbo do I have?
I bought a "rebuilt" turbo about 4 years ago and am finally getting around to adapt it to my non-Buick engine. It was supposed to be off of a Regal but just recently someone looked at it said it was not. I have attached some pictures of it here and would appreciate any response on what it came off of. I've been out of the performance game for many years and am trying to get back into it so please excuse my ignorance.
Thank you.
gstenz
turbonut85
Rarely used member
Apr 11, 2008
3,253
189
63
Des Moines, IA
Thank you.
gstenz
Unless it's off a carbed TR (78-83). I'm not 100% on those cars, but it's definately NOT off a SFI turbo regal. (84-87) HTH
che8700
9
1
3
Visit site
any help?????
one question?i just bought a four bolt turbo and i was wondering if theres a adapter to make my three bolt downpipe to and four bolt.anyone know of such of thing.
  • Like
Reactions: rick j.
RobV6
634
0
0
NY.
Visit site
RE:Could be an earlier carberated Turbo
Not sure but I had one came off a turbo Riverera.Nw I'm not saying for sire. But it is not one for an 86 to 87 buick. Just don't know. Sorry.
Would like to know. Curios...Rob
Top Bottom
