3BAR Map Sensor
my1stgn
I have the MAF Trans Gen II and I also have a 3 Bar Map Sensor. Does anyone know which wire @ the ECU is the signal from the 3Bar Map Sensor so I could tap into it with the MAF Gen II? IE pin location and color? Thanks! Or even better does anyone have a wiring diagram of the ECU pin wires? Thanks again!
map is not part of the ecm since its only function is to drive the boost/gauge which is specific to turbo cars with analog dash
to tap the map signal you can tap it at the sensor (middle wire) or pick it up on the harness that runs up to the dash connector behind the glovebox (green wire)
Thanks! I just pulled up the wiring diagram from the TType Website and I see that the "Boost" signal is only sent to the IC. Is there any benifit to seeing the MAP signal in the Translator? IE does it help to tune or does it help for the WB Tracking (i doubt it but figured Id ask)
