Howdy,
By now I'm sure many of you are familure with my, in many people's opion, crazy twin turbo 4.1 buildup. With many thanks to the members of this board I have rethought and totally revamped the plan for the engine based on the discussion in my previous posting. Now its time for the little details instead of the critical ones. The combo is production 8484 4.1 with front 3 steel caps, Eagle crank, stock rods, Diamond Forged pistons, JW flexplate, BMS "Indy Lites" balancer, Champion CNC Irons, .60/.48 IHI turbos, Alky Control kit, deltagates, and twin intercoolers all coupled to an SP400 with 1900/3000 stalls and a C4 IRS with 3.08 rear gears. The advise I need is:
A: What size injectors for this setup, I'm planning on running as much booste as the hardware will allow.
B: How much will a roller improve the durability of the engine at higher horsepowerlevels?
C: What profile cam should I use?
D: Is a Walbro 340 enough fuel pump for this or do I need a Double Pumper?
E: How much power tollerance will adding a girdle add?
And the kicker, how much power do people think this combination will hold on a durable basis both with and without the girdle?
Thanks,
Thanks,
