4.1/stage pan, timing cover, rockers, drive shafts
psiedv6
1 - 4.1 or stage block 14 bolt oil pan with pick up and turbo return line tapped into it $70.00
1 - 4.1 or stage block new timing cover $60.00
1 - timing cover for dry sump make offer
1 - set of stock rockers make offer
2 - water pumps $10.00 each 1 has #8 AN fitting welded on
1 - drive stafts $20.00
1 - drive shaft w/ yoke $30.00
1 - turbo return line $10.00
I will give you guys first shot, then ebay time
I will see if I have a fitting for the block, I am sure I have one somewhere.
How much for the new looking waterpump and new silver timing cover? Are all the parts good to use -no issues?
The price is listed above and the timing cover is new and both water pumps have little uses. The blue one is stock and tight, the silver one has a #8 AN fitting welded on. Take your pick :)
you know what, i thought they were diff covers than a 3.8 but i just posted in the tech section and nick micale tells me the easiest way is to use my 3.8 cover and mod it by drilling the 2 holes for the 14 bolt pan. what i do need is whats been sold already, the 14 bolt pan, arrrgh. oh well thanks anyways man
cory
