which rear end gear would be better for a low 11 to high 10 sec car . what would be the difference between mph and 1/4 time . and would they both be streetable.
Stick with the 3.42's for sure !!!!
You wanna tweak the ratio some if the tach is not where u want it going through the traps, then change your tire height 26, 26.5, 27, etc.
I did the 4:11 thing in my 86GN about 7 years ago. It was fun when the car was stock but held it back once I started making power. I quickly went back to the stock 3:42 gears and a taller (28") rear tire.
I would leave it alone and spend the money else where.
