4 BAR MAP
J-B Racing
Forced Induction
What do we need to do if I want to install from a 3 Bar to a 4 Bar on a XFI 2.05?
Input it in your MAP parameters as well as set the voltage chart/graph to the specs for said sensor
so that is basically all it is?
Well, kinda.
I'm sure you realize that if you plan to use the kind of boost that requires a 4 bar map sensor, then you will have to extend the MAP up on all of your tables.
You'll have to decide how you want to break up the cells.
The Cells factor I was aware. So let's clear something! A 3 Bar Map will work to how much boost!
30 or like it should 43 psi
Joe
Joe
3 Bar should work to around 30psi... atmospheric pressure + 2 additional Bar (14.5X) So 29.X PSI of Boost Pressure.
-aaron
Sent from my iPhone using Tapatalk Pro
That's what I thought when I had surpassed the 30 and the classic FAST stopped reading.
Thanks a lot guys for the help. So I will eventually get the 4 to regulate the spike boost if occurs.
Joe
