Aug 27, 2008 #1 I incharge Member Joined Dec 11, 2005 Messages 785 Where can I find 2 steel center 4 bolt main caps for a Stage 4.1 block??
Aug 27, 2008 #2 S S2V6RACER Banned Joined May 25, 2001 Messages 4,766 Try and give Dan at DLS a call. His ## is in my sig.
Aug 28, 2008 #4 B BlownV6 Well-Known Member Joined Mar 26, 2004 Messages 1,972 I can probably help you. I have quite a few caps here. Mike
Aug 28, 2008 #6 9 9SECVSIX Member Joined May 25, 2001 Messages 520 Steel Rear Cap... If your thinking of swaping out the cast rear cap I have a steel one avaiable that machined for a BBC rear main seal. Got it from "Ohio George"
Aug 28, 2008 #7 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 ? Some Stage II splayed caps are stepped.
Aug 28, 2008 #8 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 ? 9SECVSIX said: If your thinking of swaping out the cast rear cap I have a steel one avaiable that machined for a BBC rear main seal. Got it from "Ohio George" Click to expand... Curious as to what seal half you would use in the block.
