TurboTnZ06
Go on red!
- May 7, 2002
I just upgraded my MAF setup from a homemade one out of 4 inch PVC Home Depot special to an aluminum 4 inch one that is perfect for the LS7 maf sensor, and this part is cheap at $30: Spectre 9705. The slot LS7 sensor itself I got from full throttle as well as the 5 wire converter and the standard maf translator. It comes with the little screws to attach the sensor so its a nice kit. I set the translator on 4" and the cars spools up even faster than before at part throttle cruising the street. Just ignore the plastic inserts, that's trash and not needed.
