Not pressure, but volume flow. (Lb/hour).. These numbers are the maximum flow when the injector is held open. These flow measurements are usually made with fuel pressure around 45PSI [Lb/(inch)(inch)]. These two injectors do not have a big difference in their max flow, or horsepower potential; a difference may exist between their minimum flow, which can affect idle characteristics.
