I am sure this has been discussed, I did a search and didn't see anything, so here it goes. I would like to see 500 horses at the rear wheel of my 87 gn. I will give you my set up and would like opinions as to the most reasonable way to get there. Also, recently I had it dynoed and it made 365 with 470 torque. I think there is more in the combo, but not enough to get to 500.
stock block .030 over bore
stock crank
speed pro pistons
can't remember the specs on the cam, but at the time it was more than what I needed, if vital I can look it up.
good rods (can't remember the name currently).
ta-49
stock intercooler with duttweiler neck
champion irons
champion intake
walbro 340 (hotwired)
3200 stall convertor
50 lbs injectors
red's chips
translator and lt1 maf
power plate
20lbs boost on 94 octane
3" DP
Hooker exhaust system 2'5"
atr headers
I am sure I am missing something, but keep in mind I have limited access to race gas. I know everyone says put some c16 and turn it up, but I don't have access, I can get cam2, but that is it.
Thanks for your ideas.
John Wilde
stock crank
speed pro pistons
ta-49
champion irons
champion intake
50 lbs injectors
red's chips
power plate
3" DP
atr headers
John Wilde
