55lb injectors and other MISC parts
Way2QWK
Turbo Spooled by CORN
For sale of the following:
1. Seimens 55lb low impedence injectors. Flow matched set bought from Precision Turbo. Have aprox 8k miles of use. Work perfect. Went to 83lbers when I switched to e85. $125 shipped
2. PST poly front sway bar bushings and end link bushings #9.8105g & 9.5110g. Bar bushing measure 7/8" -$15 shipped
3. New OEM GM motor mount. Drivers side only. This was installed on car but never driven with. replaced for poly mounts before car left the lift. #25504647 -$50 shipped
4. New Centerline center caps new in bags- $25 each shipped
5. Used stock camshaft in good condition 60k miles- make offer
6. Aeroquip braided fuel lines. Teflon inside. -6 3ft piece and -4 3ft piece. New never used-$ 15 each shipped
7. Autometer fuel press gauge. new in box #4309. No sender, just gauge - $40 shipped
8. Te44 turbo parts-NOT COMPLETE, missing both wheels and exhaust housing- make offer
I just Googled the AutoMeter p/n to find out what size it is and seen there is a Recall on that gauge. The summary indicated the gauges mfg'd from 10/99 thru 3/02 may leak fuel. Interesting considering it's an electrical gauge.
I just googled it also, looks like the sending unit was the problem. I only have the gauge. Unsure if a current sender would work with it. I will email Autometer.
