57 high imp and extender+
scottbanner
I now run 42.5lb injectors with the extender+. If I go with the new 57 high imp injectors will I have to get the extender chip reburned, and will they even work with that setup?
what version extender?
But, in general you want to run a chip that is matched to the injectors....
Bob
yes you will have to have the chip reprogrammed to your specific size injectors...
If you have a rev F, you can adjust parameter 11 to shift the injector size. It has enough range to get you most of the way there. It will probably run fine that way, and you can plan to update the chip at your convenience.
Bob
I can't remember wich version it is. My car is still in storage. It's a couple of years old though. Thanks for the help.
