It is actually vacuum operated, there should be a multiport diaphram that operates the doors. The diaphram should be the same as the Corvette from 1968 to the early 80's and was reproduced years ago. You should be able to find one if needed. I would start with tracing all of the vacuum hoses and replacing what needs to be replaced. Check for leaks and then check again, then check again...LOL. Good luck
Bryan
