Sam Colalillo
low 9's w/ a 109
- Jan 12, 2005
I am seeling the HPQ dual ball bearing turbo off our TSM car.
* This is a Hartline speced Precission Turbo
* Dual ball bearing water cooled.
* Turbo has a .85 AR housing.
* It does not have a wastegate ( i ran an external waste gate)
* The wastegate hole has not been touched. (is not ground out or ported, so if you chose to run an internal gate you can port match it to fit your flapper valve perfectly)
* comes with the -4 stainless oil supply steel braided line which I used.
* 4" air inlet
* 3 bolt trubo
* TSM legal
* is in great working condition.
it will not come with the with the water cooled fittings which must be purchased seprately when this turbo is purchased brand new.
This is the turbo which took us to 9.27 @ 145.74 MPH in TSM competition.
At the reynolds Southern Buick Shoot out last year our slowest pass was a 9.38 on Saturday using this turbo. The ball bearing turbo spools up really fast and the 9.27 pass was made in the TSM semi finals leaving off a pro tree at Reynolds:biggrin: (which proves this turbo spools up fast!!!)
The Price is: $1350.00 shipped with in the 48 states. (that is about 1 grand off of new)
* 4" air inlet
* 3 bolt trubo
* TSM legal
