86/87 ecu on an 85?
MiamiGranny
Can i just plug an 86/87 ecu into my 1985 gn without having to do any modifications to the wire harness?
Ive heard of people running 86/7 ecus on their 84/85's just never got a concrete answer. thanks guys.
-Andres
Read post #21-
http://www.turbobuick.com/forums/hot-air-non-intercooled-tech/33080-basic-hotair-info.html
try this as well...
Ignition Module Swap
No, you don't need to modify your wiring harness it's plug in... you can add the MAT sensor in(as the 86-87 IC cars)
came with it, otherwise Eric can delete it when you order the TT chip... the MAT sensor wiring kit is available from Casper's
Ive dealt with TT before and he does good stuff. Thanks for all the help, yo guys here are so friendly and helpful. I can't thank you guys enough!!!
I have an 86-87 ECM and a 3" MAF for sale. PM me if you're interested.
