1987 Buick Grand National
Black with T-tops
Rebuilt motor
Moly rings
Comp 206 cam
Comp valve springs
Fresh 3-angle valve job
Port and bowl work done to the heads
Comp double roller timing chain
Melling high volume oil pump
Melling cam button
TE-34 Turbo (T3/T4 57 trim 545hp capable) (works great, but slowly leaks oil)
Specs on TE-34 at Precision Turbo
38 lb injectors
ATR 3 inch SS downpipe, with external wastegate and test pipe
Hooker 2.5 inch dual exhaust
Custom 3 inch intake pipe with K+N filter
Adjustable Fuel Pressure Regulator
Walboro 340 pump and rewire kit
Scanmaster 2.1
Alkycontrol.com burned ecu chip
235/60/15 front tires - almost wore out
215/60/15 front tires - extra not on wheels
275/50/15 rear tires
All tires are like new BFG Radial T/A
New filler panels (rears installed)
Fresh header panel (current one is cracked)
Extra dash panel in excellent shape (to replace cracked current one)
Extra steering wheel in excellent shape (current one has minor cracks on top)
Digital dash (stock option)
Shift kit in the tranny (unknown but works good)
Power windows
Power locks
4th gen camaro rear view mirror (has built in map lights)
3rd gen camaro tag bracket (folds down and stays down)
Kenwood DVD player (no screen, excellent deck)
Infinity 6x9 rear speakers
Sony Xplode 4 Channel Amp in trunk for speakers
lots of extra parts, misc crap ive picked up for the car, many new, many used and in good shape, all goes with.
Car needs paint badly, previous owner didnt know what they were doing and I was slowly getting back into shape. Also needs seats redone.
Ive driven the car for about 2000 miles, fun car, but im just looking to pursue other intrests.
92xxx on the car
gimme a call at 941-400-1871 - Mike
$6800 obo
Black with T-tops
Rebuilt motor
Moly rings
Comp 206 cam
Comp valve springs
Melling cam button
38 lb injectors
Scanmaster 2.1
Power windows
Power locks
92xxx on the car
$6800 obo
