A/C and Powersteering delete
The unit Cal sells is a very nice unit. I just finished installing it.
As far as the belt, I can't help you there. I never got one to put on before the car went up to Conley's for a new down pipe and they got the belt.
Take Care
Nope, no belt included. Too many diferent pulley sizes out there. Sorry it was more than you want to spend. Good Luck getting one.
The billet set up Cal sells is definitely top of the line and worth the expense.
You can use the a/c delete bracket from a truck application. I bought one from Conley a few years ago. I made a couple struts to support the alternator front and back.
For a pulley, use your stock p/s pump. Remove the vanes out of the pump. Remove the inlet nipple and press a small soft plug into the inlet and outlet.
Put a little AFT in the pump before you plug it up to keep the bearings happy. You can use a stock length belt.
This worked perfect for me until I got a mezerrie water pump.
Dave
HighPSI said:
I sell a billet one. Cost is $198
do you take paypal?
ill take one !!
Thanks in advance
I have one of the Champion A/C delete brackets, very pricey, but worth the $$. They are nice billlet units that work well, spend the xtra $$ and forget about it!!!!
does anyone have any pictures of there installe, im installing mine this weekend and wanted to see if anyone had pictures, im installing the pulley that comes off the S10 trucks
