A/C blowing thru defroster & cruise control stopped working.
rb68rr
I assume I have a vacuumn line off somewhere, but where do I start looking? Thanks, R.B.
Check between EGR valve and HVAC manifold. I put my check valve in backwards and had the same results:rolleyes: It's right behind the Round EGR on the driver side valve cover. HTH :)
There's one vac line that does these. It goes from the vac block, under the throttle body, check valve and T to EGR and then to firewall. Then a check valve and T - one line will go to the passenger side along firewall and into the car, other will go to the cruise.
What he said about the check valve.
Thanks everybody, it was the line from the egr to the ? (black square box) before the firewall. R.B.
