a/c bracket and power steering hose
ponyetr
Got a couple of problems. I recently had my engine rebuilt, and found that I have a couple of brackets leftover that are not in place. I found where one goes, but there's a little L shaped bracket that I can't seem to figure out where it goes. I think it's around the a/c pump somewhere. Also, I was having a problem with my power steering hose (5/8 one from reservoir to pump) pinching, so I'm trying to replace it, but can't figure out a route to go without the new one pinching.???
I found some diagrams to help me with the brackets, but still at a loss for the hose...any ideas?
You mean where the hose comes out of the Res.? Actually, I used the old breather tube that was on the pass. side valve cover (to turbo)... replaced with a little filter. I cut the tube in half, and used/"spliced in " the 90* section from the power steering pump Res. down to the feed hose. That eliminated the pinch, and squealing... hth
