You'll need a set of A/C gauges, an air compressor and brass fitting and air hose nipple to adapt the center (yellow) hose on the gauge set to the compressed air. Put about 100 lbs. psi air in the system and then run the A/C. You be looking for about 225 on the high side and 30 on the low side. If it'll do that, it'll blow cold. You can also leave the gauges on overnite to check for leaks, it should not lose pressure. HTH.
