AC compressor not working.
6shot
My AC compressor is not kicking on when I select the AC. It has good freon,I put a jumper wire on the low pressure switch & noting. I do have 12 volts at low press switch when I selcet the AC to on. No volts at the AC compressor switch when I selcet the AC to on. Is their a relay for the ac system and what is the location of the relay? Anything else to look at & all help will be appreciated thanks.
Ralph
A/C cutout relay.
Make sure the ECM/SOL fuse is good. 10 amp.
A/C fuse has to be good also.
Relay is right next to the ESC module on pass. fender.
First relay from back of car towards the front on that side.
