AC Delco MAF
turboaddict2
I found my AC delco maf sensor that had a split between the two plastic halves that come together. I can open the splitted side of the maf. Is it ok to use krazy glue and it will become functional again? Also, I grinded the inside lip and there is dust all inside the maf and the electronic board. Whats the best way to remove it?
I found some electrical contact cleaner at Autozone and I used that. I don't know if I
sorry, fat fingers.
I don't know if I would use crazy glue but some 3M plastic emblem adhesive would work better. But spray with contact cleaner and then blow dry with low pressure air.
paul
You can get the stuff at Walmart or I think even Autozone carries it. Works great on plastics.
paul
