Adding first two gauges! Which ones? Brands?
84GNTTYPE
Senior Member
My car is completely stock right now. I'm in the process of getting my car tuned and then would like to begin modding as my budget allows. Before I do the fuel pump, afpr, downpipe, wastegate rod, etc I want to put in a couple of gauges. For sure one will be a boost/vac gauge and I was thinking of the second one being a knock gauge . . . but what do y'all think? Should I do a knock gauge or maybe something else would be more useful? Also what brands do you all prefer/look good in the GN!?! Mechanical or electrical? Digital display or analog?
Thanks for everything!
IMO, add three gauges: boost, oil pressure and water temp. Forget the knock gauge unless you like light shows; a Scanmaster will tell you more.
Good luck!
Morgan
'87 GN; 11.07 at 119 with TC problems
The advantage of a knock gauge (especially when coupled with a knock alarm) is that you will know to get out of it immediately. Scanmaster you will likely be well into the knock before you can get out.
boost/vacuum and electrical fuel pressure gauge...
get a scan tool too!
