Mine is adjustible but it seems i've got it turned in to its maximum - but i'm only seeing 10-12 PSI.
If I cut off more of the end of the rod - it will be awful tight to get the rod back on to the flapper.
I read Ken Mosher's DIY Adj Wastegate diagram on gnttype.org but I cant figure out where to get a pipe coupler for the middle. That way I could connect it loose to the flapper and then tighten it up once its on - where the way I have it now I gotta turn the end that attaches to the flapper first then attach it.
Whats everyone else got for an Adj Wastegate ???
