Daniel Jost
Squirtin six
- Oct 11, 2003
I have a couple things for sale that I'm selling from my current setup, and that I had laying around. I'll try to get pictures soon.
All Prices Are Plus Shipping;
- Innovate LC-1 about a year old with a new sensor that has less than 1000 miles (Mostly on E85) $130
- 86-87 Stock upper plenum that has been chromed and mild ported, chrome is pitting. $30 SOLD
-86-87 Stock Throttle Body, Has IAC and mount but wire plug port on IAC is broke $40
-3 Gauge Full Pillar, Gray in color in good condition with some minor wear. It has 2 LED's mounted next the the gauges that I used to use for Alky/Fan indicators. $40 SOLD
- RJC Boost Controller $25 SOLD
- Home made Megasquirt3/X to Stock Buick Harness Adaptor, It has the wiring for COP, 2-step, Boost control, WBO2 already wired. If you are following my "Going Megasquirt" thread you could Probably make use of this. -$80
- 86-87 Stock WG actuator. $25
- 86-87 Billet Vacuum block. $20 SOLD
- 86-87 Good working TPS. $25
I might have more stuff I can add later as well, I will need to look through the garage.
-I have found a Auto Meter Electric Water Temp Gauge with the sender, it is a Pro-Comp Ultra-Lite Series. $30
- 86-87 ECM with correct Cal Pack and Turbo Tweak 42# Injector Nitrous chip in it. $55
,Dan
,Dan
