If order to get any accurate info from an A/F gauge, you have to have a wide-band O2 sensor. The stock O2 sensor is a narrow band. IT switches from a higer voltage to a lower voltage as it crosses the design A/F point. Above and below that point, the voltage readings are NOT proportional to the A/F ratio, so the gauge won't display accurate readings above or below about 14.5 to 1. But if it did, what would that info buy you? Unless you have other info to go by, like HP output, knock, EGT, and BSFC, you don't really know what A/F ratio is good, and what is bad. So really, you're just as well off with the EGT readings and the knock gauge, and don't bother trying to measure the actual A/F ratio.
