Airbag install
BarnesGN
Do you take the spring out or should it slip in?
I do not have an airbag yet so I have no idea what your supposed do with it.
Sam
Spring stays in place. Air bag you will deflate and crumple to get inside the spring. Careful routing those lines away from heat sources or areas that can pinch/ punchure them. Jack the car up on frame to extend rear springs for easier access. HTH.
