Razor a few questions:
1. When doing the injector install into liquid intercooler I couldn't us either of the combo flat/rubber washers, because the lip of the intercooler is too thick for the threads to come through. So I used some 'plummers' tape on the threads. Will this be enough to seal this connection with pressure of the injector?
2. I'm assuming that the longest braided line goes from the output of the pump to injector nozzle and shorter braided line runs from the alky bottle to in the input of the pump. If I'm correct or incorrect let me know.
3. What is the clear hose used for? Is that for radiator overflow to the overflow bottle?
4. Should the entire PAC unit be installed inside of the vehicle?
